Trying to trace out all my exhaust leaks. Found water (probably accumulated moiture) dripping from the connection below
I assume this is not normal?
Which connection in the diagram are you referring to? The #1 gasket blows and is an exhaust leak on almost all 60s. SOR sells a stainless steel pipe with a better flange on it. Sorry if you already knew this. The OEM gasket is better than the aftermarket one.
EDIT: Now I see your box. Have you replaced the #2 tube recently? You usually also have to replace #26 when you replace the tube.
Maybe I'm just cheap...be cheaper to make something of your own.
