...on the way to the Official Trail Ride that is.
Tucker, I found out a few days ago, didn't even see that big lonely rock in the middle of the trail that bent the tie rod on the pre-run.
Sooo, I get a nice used tie rod with ends from arcterex in Texas. Cleaned and prettied it up and was going to install it Sat but found out the son is going to use it for a few days starting Sunday.
I had the wheels off but couldn't get the tie rod out of the steering arm.
Point of the story is, when I put the wheels back on I noticed a slight wobble when I pulled back and forth on the tire. Not good. Other side was ok so I checked tightness on both but the RH side still had play.
Tore into it late PM and found badness. Not totally rusty but some and little grease.
With time, money and energy running out, I opted to inspect the inner bearing only(not as bad as the outer), clean and repack the outer, slop some new grease in the between pocket and button it back up. For now.
Now I need to assemble some parts and replace or repack all four front bearings in the next two weekends(DD for the wife & can't be down during the week).
Sadly, not enough time and $$ for a full birf service but that will be on the plate sometime this summer.
So, there you go. Fun times. And you thought you were having fun this week!!
Just a peek into my life as a Land Cruiser owner.
McGrew or Bust!!
McGrew or Bust!!
