I'm writing this for the sake of discussion and not to say I'm right and you are wrong, Mace. If the replacement bearings are the same as the ones being replaced then, other than the new races being set in a little differently than the originals, how can the new bearings affect the shim requirements? The FSM seems to support the thought that bearings don't affect the shims needed.
Bearings - new vs. old. Of course you can reuse existing races with new bearings - they will fit with no problem but wear of the new bearings will be greatly accelerated by the grooves, even minute ones, in the old races. This effect of an old race damaging a new bearing is called brinelling, I think. Whatever, the bottom line is that the new bearing wears out way more quickly than it would have if a new race was installed.
Last thing, I agree with you about wheel bearings being designed to last the lifetime of a Cruiser - IF they have been properly maintained and since most of us came to own our Cruisers after they had been in the "care" of POs, whose to say they have been well maintained?
Mace said:The shims will differ dependong on the bearings...
The bearing races can work with other bearings. However, most of the time the bearing races have a grove built into them over the years. so the race kind of fails before the bearings do.
I am positive that you will be okay Spook. just Make sure that you put the stock ones back in and measure preload. If you need to make changes then do it on both sides (althoug it is funny, my 40 had no shims on the bottom side.)
you done yet?
