- Joined
- Sep 4, 2020
- Threads
- 122
- Messages
- 1,647
- Location
- Brunei Darussalam
- Website
- eurasiaoverland.com
I've come around to a number of suggestions from our sages to run a solid spacer on my (rear) diff. This deviates from the FSM procedure using the crush tube and would seem to eliminate the problem of removing the outer pinion bearing while the crown wheel assembly is in place.
As I see it, the procedure would now be as follows:
-Set pre-load on pinion shaft bearings
-Set backlash on crown wheel and preload on carrier bearings
-Check contact pattern (and re-start process if pinion shim needs adjusting)
-Remove drive flange and add oil slinger, oil seal. Torque and stake pinion nut.
Is this the correct order?
Also, what sort of torque should the pinion nut get? With a crush spacer the torque required is huge (300-400 Nm ish) but this is just to create enough pressure to get the sleeve to crush. I'm thinking something like 120 Nm should be good.
Appreciate any advice from those who have set up a diff themselves with a solid spacer.
EO
EO
