VT,
I like your idea on this and I think it would work with my relay setup that I am working on. So where does the capillary tube go? Does it wrap around the evaporator or go inside the ductwork just after the evaporator?
Don
Let me look into this again , I believe it was defiantly inside the evap and on a tube , but where in proximity of the expansion valve ,that is where i need to check. My manuals I will see later , Im mobile & should be back tonight .
This would give me some adjustability to how long the compressor stays on in relation to the temps in the evaporator, right?
Don
Correct , and there is a micro adjustments to trim out the cycling ..I am still going to have safety's and timer delays installed. Must have some blower speed, compressor hi temp , high side receiver drier over pressure switch , freeze up sensor, Delay on Compressor start after 15 seconds of alt charging/ and no charge , compressor cuts.
This is nothing new , normal euro early style say 75-1990 ..
I am not going to use the Amp , but maybe some sensors it uses. KISS system.
VT
Now that Mr Kevin Rowland posted , he reminded me of a question for him.
GEAR SHIFT LOCK !! got one to sell ?
VT
