Builds A Boomer GX Build.
Boise, ID
After moving to Idaho a couple years ago, I decided an SUV would be a more suitable vehicle for getting out than my previous 2007 Tundra regular cab. The tundra was a great truck but I was wanting somethings smaller and more comfortable to do some longer trips. Ive always been a fan of the Land Cruisers and when doing some research ran across the GX470s. I knew that was the answer and began searching for a solid example for sale. After a couple months of searching, I ran across a well maintained 2008 model in blizzard white with charcoal interior. I was hoping to avoid there white due to the peeling issues but, given the vehicles overall condition and service history, decided to make a deal and pick it up. Here it isin WA ready to head back to ID:
I cruised home without issue and began planning to do some maintenance that was due. The timing belt needed done and I wanted to do what I could to take car of the paint.
The timing belt job took a couple days but gave me the opportunity to replace the coolant, water pump, all the idler pulleys, belt tensioner and the serpentine belt. I went ahead and changed there oil while I was at it. I noticed the factory skid plate was fairly crusty while removing it and decided to replace it with an aftermarket aluminum plate. RCI happened to be running a great deal at the time and I opted to pick up their plate. Couldn't have been happier with that choice!
Next came time to try and preserve the paint. It has its share of wear and tear from the years but is decent overall. I opted to clay it well, polish out any minor damage and ceramic coat it. I chose the cerakote brand coating as I've had good luck spraying their firearms coatings. It turned out great and will hopefully help keep the blizzard white as nice as possible.
continued...
Next on the maintenance list was tires and brake pads/rotors. The brakes were in good shape but I prefer a ceramic pad and wanted to go with a geomet coated rotor to compliment the new wheels I chose to go with the new tires. I went with some machined RRW RR7-S wheels in 17x8.5+0. Wrapped them in 265/70/17 Goodyear Duratrac RTs and installed some powerstop geometry coated rotors and ceramic pads. I opted to paint the calipers while everything was apart and I think the silver looks nice with the white paint and machined wheels.
Continued...
Wanting to get out and do some day trips mushroom hunting and enjoying the outdoors, I decided I needed to build some drawers. I ended up designing a two drawer system approximately 36"x41"x11" and began building it out of 3/4 plywood,
the drawers were built around the popular 250 pound slides and I opted to make the top removable for easy servicing and future modifications. The left drawer includes a butcher block table top and the right drawer has a half height side to make it a little easier to get storage containers in and out. In hindsight, I think this allowed the drawer to twist slightly and I probably wouldn't recommend it.
Next up was finishing and I opted to shoot it with some Raptor Liner. Ive sprayed gallons of the stuff in the past and really love the product. I rolled on the fist coat reduced slightly for coverage and sprayed the other three bottles through the included gun. (the garage was too cold so got to spray in an apartment that was being renovated :D)
Continued...
I was able to get out and enjoy a few trips before deciding I really want a fridge setup.
I opted for the Dometic CFX3 35 and figured id run it off the PLB40. Figured it would charge alright off the factory inverter so wanted to build a mount for it near that location.
Continued...
I modified the battery with some amazon tie down loops and will hold it down with some 3/4 roller cam straps.
Im still waiting on the Alucab tilting slide to ship for the fridge but hoping it all works out in the end. that's it for now, but will hopefully be able to update shortly! Thanks for checking it out!
Nice job on doing all these things yourself. Very handy you are.
That battery stand is a clever use of the space.
I have my Bluetti EB70S power station sandwiched in between the ICECO APL35 (on a slider) and a Plano box. This makes the Bluetti display and power plugs hard to access
Welcome and congratulations. You could sell that setup in the back. Clean work.
Much appreciated! I was looking into similar power stations and it just seemed the domestic was the most straight forward for what I was doing. Convenient that it fits right where it does!
Thank you! Building it made me understand why some of the commercial ones cost what they do! It’s a lot of work putting them together!
this is awesome! great work!
Thanks!
Went out morel hunting to test the fridge and slide. Worked pretty well overall but had an issue with strapping the fridge to the slide. When strapped tightly enough to not slide, the strap spreads the fridge enough for the lid not to latch. I pulled the fridge off the slide to figure out a solution and realized there was threaded holes on the bottom of the fridge. Ended up just drilling holes in the slide and bolting it down. Much better.
The built in inverter wasn’t cutting it with the fridge. Decided to install the dometic fridge wiring kit to better charge the PLB40. I only wanted the PLB40 to charge with the ignition on so decided to wire it up with a relay triggered by the switch for the inverter outlet.
I also decided to modify the dometic fridge cable to a coiled type. Ends are a little ugly but it works well and was much cheaper than buying one.
Nice work. I have a couple of questions.
Is any sort of primer recommended and/or required for the Raptor liner adhesion on plywood?
Those SDHQ battery terminals look really nice, but doesn't that introduce a whole mess of dissimilar metal action? I think of all the crap electricians go through in a house where some wiring is aluminum and some is copper.
I have such a love/hate relationship with all of the nesting storage options these days. Packout is a great system, but you can't slide any of that crap around, and there are so many little facets and bumps that they all get stuck trying to get them out of a pile or stack. I have a mix of Milwuakee, Dewalt and Rigid stuff.
most of the Milwaukee ended up due to a crazy sale. The Rigid I use daily. In Dewalt, I have a bunch of the hardware bins with the removable cups I got a few years back around black Friday when they were $10 each.
All that being said, that packout slide is a neat solution.
I didn’t prime the plywood. I did reduce my first coat about 20% and rolled it on with a 4” roller. Think that helped it soak into the wood.
I’m not educated enough on dissimilar metal corrosion to be able to answer your question on that. Time will tell but I haven’t heard any complaints about billet terminals.
I’m a big Packout fan but I have some of the specific tools and stuff that works with the system. The aftermarket support and local availability of Packout stuff really makes it an easy choice for me. Paying for it is never fun though!
Thank you.
I have one of the packout rolling boxes, that thing saved my butt for some handyman type work we got in a 36th floor condo. I've also been really happy with the packout M18 fuel vacuum.
Thank you.
I just recently picked up the vacuum and couldn’t agree more. Way too handy!
