Wanted 99 LX470 / 100 Series window trim - passenger side front and rear
Truckee, CA
  1. LX470
Mine is all flaked out, half coated/half aluminum showing. To be clear, this is the strip at the base of the window.
Just order it new. All used ones will be doing the same shortly.
Take a look on Ebay.
Search for belt molding.
Prices are way cheaper than what I paid about a year ago from a Saudi supplier.
I don't know about the quality on the cheaper priced ones.
Used ones would be trashed by removal.
Thank you! Saved probably 50% ... and so when they don't show at least I'll only be out half for what I would have been.
The front doors each have one screw located on the top-inside of the door jamb. Remove those and pry the old molding up with a plastic trim tool.
The rear ones don't have screws.
Make sure that the new molding is aligned correctly before seating it.
Here's my kit! OEM or bust (part numbers on my website if you want to source them elsewhere)
