*** Late edit added referring to AHC-B fuse, AHC-IG fuse and AHC Main Relay ***
I was writing a few thoughts while others were doing similar. Given that @suprarx7nut is much closer to you and is very knowledgable, suggest follow his lead in his Post #4 above in this thread, rather than have too many diverse views. Meanwhile, I may as well share what I had already written in case any of these ideas are of assistance:
It seems like you have access to the appropriate Factory Workshop Manual (FSM) but just in case, here is a good on-line reference:
https://lc100e.github.io/manual/
then work through tabs at left hand side of the opening page to find:
Repair Manual > DIAGNOSTICS > ACTIVE HEIGHT CONTROL & SKYHOOK TEMS
(This is an LC100 version but it applies equally to LX470 which is basically the same under the skin).
The exact conditions causing each of these DTC’s are described at this FSM reference.
Note that Techstream is not indicating DTC C1761 – Malfunction in ECU.
However,
- AHC light is blinking, and,
- No raise or lower function
- Harsh ride
Actions taken so far:
C1732 – Control Valve Solenoid and Accumulator Solenoid Circuits
--- tested solenoids on both devices per FSM and found satisfactory.
C1763 & C1764 – Fluid Pressure Abnormality
--- no actions reported.
Note that C1732 is consistent with C1763 and C1764. These DTC’s are likely to occur together because, as seen in the extract far below and regardless of the electrical health of these circuits, C1764 means that the ECU has prohibited the operation of the Height Control Accumulator solenoid
and also prohibits height control – meaning the raise/lower function is prohibited. Not stated but also it is likely to include prohibition of active damping which means rough ride. This situation does not indicate an ECU failure.
Suggest pursue each of the causes listed under “Trouble Area” in the relevant section of the FSM (extract below), including the pressure sensor even though a pressure sensor DTC (C1762) has not appeared.
Note the particular 'fail safe' mode which occurs in the case of C1764. This would appear to correspond with your described symptoms.
As a starting point, suggest first use the Height Control Operation Test (also called the “Active Test” ) to determine whether the height control functions are
capable of working if the fault conditions are resolved. See attachment at Page 6 – Item 5. Special Service Tool (SST) 09843-18020 is mentioned which is just a short jumper lead. Instead use an unbent clip to bridge the terminals shown. With ignition OFF, make the connections at DLC1, (usually in the engine bay above the RHS front wheel with the word "DIAGNOSTIC" marked on the cover), then with engine operating, perform the test exactly as described in the attachment. There will be an array of warning lights in the instrument panel during this test because parts of the circuits are being bypassed. These will disappear when the test is complete and the paper clip bridge is removed and the ON/OFF switch is pressed and held for a few seconds. (This procedure is similar to the FSM but for better convenience uses DLC1 rather than DLC3).
If there are no height control functions when the "Active Test" is used, then it is time to suspect the AHC Pump – either a lack of power, or, a possible blockage.
For power supply, check AHC-IG fuse as shown in “Power Source Circuit” in the FSM reference. Suggest also check the AHC-B fuse and the AHC Main Relay – see test details in the above referenced FSM section on AHC Diagnostics for C1743. Also see this link for background information and details which may help.
Quick question about AHC ride with extra weight - https://forum.ih8mud.com/threads/quick-question-about-ahc-ride-with-extra-weight.1247828/page-4#post-13959941
The point is that if power cannot get through due to fuse or relay problems, not much is going to happen in the AHC/TEMS systems.
Then suggest cut to the chase and test the AHC Pump by connecting the Pump Motor directly to the battery, making the connections exactly as shown for for DTC C1762 (even though this DTC is not showing). If the Pump can operate but there is insufficient pressure and flow, then a Pump blockage might be suspected.
Perhaps that is enough for a start.
