- Thread starter
- #41
The LC registered and inspected it passes emissions first time. For the gm pcm i had it programmed from lt1swap.com
the ford contour (cougar) dual fans work great . i just wired them up like they would be in a GM yukon. 3 relays that utilizes the cooling fan1 and 2 on pcm which gives it 2 speeds. Amazing is the gm pcm speedo signal works with the stock LC speedo. i hooked up scan gauge and it is close to same speed. i will check later the actual speed of LC. i will post more pics when i get around to it. and thanks to warpdrive he has helped a lot.
