96 Power antenna wiring
Germany
A previous owner of my FZJ80 was a little bit "creative" with the audio wiring, which I am currently fixing. In the process they have messed with the power antenna. Does anyone know where the cable coming from the antenna plugs into? The PO cut off the connector and spliced it into the adapter for the new radio...
I do have an unused plug behind the radio, as seen in the picture below. Since I changed to a manual antenna, I was thinking about using the wiring for winch controls.
I assume you're asking about the power lead from the antenna? It is connected to the antenna switch on the dash, through connector 1F1, terminals 12, 13 (as shown below):
Here's the complete switch (A21) (dash) wiring:
Terminals (1) and (6) are the light in the switch
Terminal (2) is the ground
Terminal (4) is connected to the main cabin fuse block
Terminals (3) and (5) are down and up on the switch, respectively
All of these wires are routed from the switch into connector 1F1 and then to the appropriate terminations
The numbers adjacent to the connectors are the terminal's locations in those connectors. See the first image, post #2.
That was exactly what I needed!
Thank you!
I also downloaded a wiring diagram from the internet, I don't know why I haven't thought about that in the first place...
...it's always the simple things.
FWIW, the complete Toyota factory service manuals (FSMs) are in the Resources section for free download.
NP, the FAQ and Resources sections are (I think) the most valuable, and most underutilized, sections of this site.
