I've got a stock 96 w/approx. 146K miles and front/rear factory lockers. I've seen tons of writeups on the birf job and also have the DVD but nothing really addressing the state of the front lockers during the process. It is my understanding that the front lockers need to be locked prior to beginning the birfield disassembly. Is this correct? FSM states to lock them prior to removal of the front differential but I did not see it referenced elsewhere.
Question 1.) Why does the front diff need to be locked?
Question 2.) If the front diff is locked should I expect a problem trying to rotate the flat side up on the birf prior to removal?
Question 3.) Should I expect any added difficulties with the process due to having front lockers?
Thanks in advance.
Thanks in advance.
