Here's an intermittent problem with a stock 96' LC w/105K miles. The problem has a happened a few times and the worst was yesterday. The truck starts but the starter continues to try to engage and re-start the engine. Although the engine is running the idle is rough. Yesterday, I started it (cold start), the starter continued to turn the engine over after it was started. I turned the ignition off (which worked in the past) and the starter still continued to turn the engine over even though the key was off (and the engine was off). After turning the key on, and restarting the engine and off again the starter would not stop turning the engine over (whether the engine was running or not). Since I couldn't get it too stop I popped the hood and gunned the engine @ the throttle linkage. This finally made the starter operation return to normal and I haven't had the problem again. I initially had this problem about 3 months ago, although not to this extreme, and maybe once since then.
Might this be a solenoid problem? or could it be related to the computer system?
