- Location
- United States
Well folks wife & I are looking to get a tow rig & trailer so its time for a rig to go...... wife says hers is up for sale.
Its a rig you can purchase, drive to a event, wheel, drive home.........
We have own it since 112k.
Only issues:
DS has key marks
(pictures show this)
Normal trial brush scratches
steering wheel leather worn
96 LC w/ 209k Miles= by KBB
Exc condition - 7520.00
Good condition- 6870.00
Fair condition- 6045.00
Add on's:
ARB Bumper w/ Warn 12k
Slee receiver dryer cover
ARB lights
J springs/ w L shocks
DC front Drive shaft
Slee Caster Plates
Iron Pig rear bumper w/ swing out
Tires(5) 35x12.5x16 Swamper Trxus Radials
Man A Fre adjustable pan hard bars front & rear
Sliders welded to frame
Retro fitted front & rear e-lockers w/ 4:88 gears
Landtank MAF housing & sensor
Brake Controller w/ 7 pin connector in rear bumper
Iron Pig dual battery kit-NOT INSTALLED
Full set of front & rear shafts included+ birfield+ F/ R drive shafts
New o2 sensors not installed..... NO check engine light
Front axle rebuild kit un-opened
Total add ons Retail= $6850.00
Maintenance Done or replaced items:
changed oil every 3k w/ Toyota filter & 10w-40 castrol
trans service every 15-20k
heater hoses changed
belts changed
ac compressor/ clutch/receiver dryer replaced
fan clutch replaced w/ blue one
oil pump o ring & front crank seal
ps pump replaced
lucas in all diffs & case
heater valve replaced
speedo o-ring replaced
starter replaced
alt. brushes replaced
Intake tube replaced
PHH replaced
Tie rod ends
Birfields replaced
valve cover gasket & spark plug o-rings
front brakes are 100 series pads/ rear has 1 old rotors & pads
*HG has not been replaced- does not use coolant*
With add ons & stuff to go with the truck I came up with this:
Splitting fair & good=$6400.00
Add ons= $3425.00 ( half of the retail value)
Price for truck
$9825.00
* clear title in hand *
Please PM me if you interested.
Located 20 minutes south of Nashville TN.
Can arrange drop off or delivery for $.
Only issues:
DS has key marks
Add on's:
ARB lights
Slee Caster Plates
belts changed
ps pump replaced
starter replaced
PHH replaced
Tie rod ends
Birfields replaced
Price for truck
