SOLD 95037 Bay Area 1997 fzj80 $12000
Year
1997
  1. 80 Series
Morgan Hill, California United States
Mileage
360000
Color
rgb(145, 255, 0)
Outside Link
https://www.instagram.com/betty_the_fzj80?igsh=NTc4MTIwNjQ2YQ==
Betty is up for sale
1997 1FZFE
Her coolant Bypass hose just sprung a leak, lost a tiny bit of coolant (i commute
4 mile and noticed it) i have the hose and many other extra parts)
$12k
356,000
Head gasket was replaced in 2007 @265,000 by Capital Toyota it’s in the Toyota Maintenance database
The 1FZ-FE is legendary
I’m the 2nd owner, purchased from a neighbor (soccer mom/kid transporter)
Brand New Quadlight setup from ASR Parts ($1300)
New Toyota grill
2” Iron man springs with 3/4 front leveling spacer.
OME shocks
Black Hawk 3” lift Radius arms $1600 (castor correction the right way)
All new sway bar bushings and new exhaust hanger bushings. All new 555 Tie Rod Ends with Manafee heavy duty drag links.
Frant and rear adjustable panhards bars.
All new extended brake lines (Toyota OEM) all new OEM Toyota caliper lines. New Toyota OEM rear calipers, rotors new pads. All new sumitomo wheel bearings front and rear. New front brake rotors and pads Front calipers were rebuilt with OEM Toyota parts.
Valve cover gasket and full tuneup kit (OEM plugs-wires etc)
New Pesky Heater hose
All new heater hoses and new rear heater hoses.
New radiator, new OEM radiator hoses, thermostat, new Aisin water pump. New OEM Toyota Harmonic Balancer (like $500 new)
New OEM Toyota Fuel pressure regulator and fuel filter.
New Tom Woods front Double Cardon drive shaft
3D printed overhead console
Hurricane fab tailgate storage
Battery cable upgrade
Comes with Photoman Bills alternator upgrade kit and Sequoia Alternator (not installed)
Replaced almost all the window runs and window rubber scrapers.
all new Toyota dash AC vents including speedo cluster screen.
LS400 visors
Rear cargo area has sound deadening applied
Rebuilt Transfer case
High/low gear
White Knuckle Off-road Sliders
Wits End Power steering cooler
$300 (not installed)
Prinsu
New center dash
LS400 visors
LX front seats that have been re cushioned and covered
Sold….
Bye Betty, it was fun I will miss you. Wish we could have remained together 😘
