For Sale 95 FJ80 in NY - Locked, Built - 180K miles
Hi all, I posted this on CL while out west, but it didnt sell before I had to get back home. Now Im back east, took new pics and putting it up again.
1995 FJ80 with 182K - $21,000
The good: This rig is totally built. Triple locked, slee 6" lift. With the exception of the winch (explanation below) she's ready to go. I just replaced the inner axle seals (so no birf soup), and in the process inspected the other seals, bearings, bushings, and birfields - no signs of wear. I also pulled the front diff to replace the seal and the wear patterns and backlash are to spec, very little wear. Interior is in great shape and super clean for its age. Seat covers have been on for years. Never smoked in and no rust. The ARB tent is 5 months old and barely used / super clean. New fluids all around.
The not so good: The chromoly front axles are longer model and the flanges are the short model. The dust caps wont fit on with this configuration, but it really isnt a problem since the hub caps keep the dirt out. You can get a pair of the long flanges for $160 new or next to nothing from a pick-a-part. Exterior cosmetics: Fenders were originally cut to fit different bumpers, so they don't line up perfectly with these bumpers (minor). Coating has come off the slider steps in places and theres surface rust. Roof and quarter panels had a so-so repaint awhile back but is already deteriorating. Chips and imperfections all around. Sides pinstriped from forest trails. No dents though.
The bad: Winch isn't spooling in or out, it happened suddenly when I was spooling in under no load. From what I read the solenoids were most likely culprit, so I replaced those but no luck. So the wiring must be at fault, I haven't had time to isolate it but if you can use a multimeter should be an easy fix. ABS Light is on due to a pinched F R speed sensor wire (splice them for an easy fix or buy a whole salvaged harness for $150). When re-routing the exhaust one of the cats was removed. I went to a smog shop in CA in late May and it passed everything but the visual test since these trucks are supposed to have two cats. Local shop quoted me 600 to splice in 2 new cats. If you are in a state with more lax smog rules this is no problem at all. It passes in NY no problem, passed inspection here last week.
I did not build this truck. Previous owner had it for over a decade. Over the years he built it up, doing all the smaller stuff himself and having reputable shops do the rest. I have most of his receipts, and pictures of work he did. I just added the tent.
I bought the cruiser specifically for a road trip which has now come to an end. I've put about 10,000 miles on it since Ive had it, about 400 of which were on dirt roads, with about 40 miles of mild crawling. I love this rig but it belongs with someone who can put to good use. I live in Brooklyn, NY where they salt the roads, I dont have a garage, and I'm trying to buy a home - so thats why I'm selling.
There is the possibility of including spare doors, rebuilt engine and transmission in the sale if buyer is willing to arrange and pay for shipping from northern Utah. A few hundred $ worth of diff and wheel bearings and seals included regardless.
I’m open to the possibility of delivery within a day or two drive from NY, but we’d have to discuss the particulars obviously.
LIST OF UPGRADES
--Suspension/Steering
- 6" Slee springs
- Slee spacers bumpstops swayer blocks and brackets to compensate for lift
- Caster correction plate
- Sleebuilt front and rear billet lower control arms and bushings
- Front sway bar disconnects
- Metaltech adjustable pan hard bars
- Slee drag link
- Power steering cooler
--Drivetrain
- Slee chromoly birfields and axles
- Chromoly drive flanges
- Double cardan drive shafts
- 4.88 gears
- ARB Air lockers
- Gears and lockers installed in diffs by Low Range Off Road
- rocker switches for lockers on dash
- ARB onboard compressor
- Five 315/75r16 General Grabber AT2 tires (75% tread) on stock Toyota rims powder coated black
--Exterior
- Slee slider steps
- Slee belly plate
- Slee front bumper
- Slee dual swing out rear bumper with ladder, spare, hi-lift jack
- RotoPax swing carrier mounted to ladder
- Bumpers coated w bed liner
- Custom hitch
- Chinese Safari Snorkel
- Roof rack
- Vent visors
--Electrical
- Dual battery setup with blusea fuse blocks
- Yaesu Ham radio
- Uniden CB radio
- Pioneer Head unit with amp and JL Audio sub in rear
- Dash mounted ScanGauge OBD II
- Tuff stuff LED lights - front bumper light bar, roof rack light bar, driving lights custom cut into bumper, two rear lights mounted to roof rack - rocker switches on console
--Other Expedition/Adventure stuff
- Warn 9.5TI winch with synthetic rope
- RotoPax containers: Four 2-gallon gas (8 gallons total) and two 2-gallon water (four gallons total)
- ARB roof top tent
- Two maxtrax with roof rack mount
- Outback Solutions dual cargo drawers
- Eezi Awn swift awning
--Interior
- Mild mirror tint
- Wagon Gear tailgate storage lid
- WeatherTech floor liners
- Cordura seat covers - no one has sat directly on the seats in years
More pics in next post
Just ordered new OME Nitrochargers, should have on first week of July.
Fixed the winch, turns out it was a faulty ground inside the motor. Pulling strong now.
cool rig, GLWS. BK street parking is rough, perfect rig to sell to summer crowd out east.
