94 hzj75 fog light help (4 Viewers)
Sacramento,California
Looking to install the factory fog lights on my Hzj75 troopy. I have seen a thread on this but was hoping to get some definitive answers.
Is there a dedicated plug in on the harness? Is there a plug in the dash? What is the correct fog switch?
Hello,
There is a plug on the harness in both the engine bay and the dash.
There is a socket in the harness above each fender in the engine bay, close to the headlights.
There is a plug for the switch in the central dash, below the heater/AC controls.
Fog light switch part number is 84160-90K01.
You will need two extension cables, part number 82132-60051.
Juan
Hello,
Juan
Juan, It looks like from the diagram that I need wire extensions for both sides. Do two extensions come with the 82132-60051 or do I have two order twice?
Hello,
You have to order twice.
One cable for each side.
Juan
Thank you Juan, What fog lights are correct for this to plug and play?
Hello,
You can use the factory lights, p/n 81210-60080.
It is plug and play with factory lights.
Provided the lights you use have the same connector as the cable, it is plug and play.
Juan
can you show a picture of the plug and locations?
Hello,
This is the plug, on each side of the engine bay. It is close to the headlights.
Juan
