For Sale '94 FJ80 - $12,500 OBO -VA
Selling my baby because we’re moving back overseas, Nearly all of this was done by the previous owner. I used this truck for camping over the past year, and thats about it. i had great plans, but life got in the way and now we're moving again. Supposedly the engine was rebuilt at 150K, but no documentation. Odometer now reads almost 210K. Previous owner did all the work himself, and it looks really good. Since I've had it, I've put about 5K into it with rebuilt front knuckle, wiper motor, put all new window regulators and motors, new ac compressor, new ABS and replaced the light force fog lights for LED bar. Winch works great. Never messed with CB, but i get the static and channel search like it works so presume so.
I had grand plans for this of dumping a TDI engine in it and keeping forever. Unfortunately, uncle sam has other plans and I’m off again. I use this as my daily driver, about 27 min each way, and have had zero issues- its a tank. If i were keeping I’d put a new exhaust on, only b/c the catalytic converter rattles inside so something inside is loose, I just haven't got around to it. VA inspection is good through Feb '19. The rear passenger window is slow to go down, so needs the stripping around the window replaced. The others are all good.
The previous owner passed on to me a tub of parts he used during his mods, the third row rear seats, and a tool kit of handy stuff along with a high lift jack. I added jack stands to that, and the few mods listed above.
i’m asking 12500, but will take OBO.
It's a beast of a machine and runs like a champ and really sorry to have to part with it, but just can’t justify storing while we’re overseas.
I have all records of the mods and everything from our local shop here that has kept her serviced.
Ripped out all carpet, POR 15 on any surface rust covered.
Installed new thermally-backed carpet (stock brown)
Cut out two rust-through points in rear fender wells, welded patches, rust proofed, primed
POR 15 inside of both fender wells
Cut out bottom of drivers door bottom edge, rust proofed, primed, POR 15 insides (as well as all other interior door bottom edges)
New windshield
Replaced sunroof
Bedliner applied to lower half of truck and hood
New 4x4 Labs rear bumper with spare tire mount and ladder, single swing out
New wheels and Dick Cepek crusher tires (315/75x15)-5
New 3” Old Man Emu lift (springs and shocks), with front control arm drop kit and steering stabilizer
New Kenwood head unit with HD radio, bluetooth, DVD, dual camera, 150W, 6 speakers and 8” sub with 1000W amp
New CB radio with 5’ tunable whip
Completely new AC - compressor, pump, evaporator, all new seals
Rebuilt front knuckle, bearings and seals, steering knuckle felt/seals
New front rotors
New front and rear calipers and pads
Replaced front and rear differential fluid and transfer case fluid (no visible signs of issue in the fluids)
Mile Marker 10,000 lb winch with remote
New LED light bar
Recently Replaced:
New wiper motor
New window regulators and motors all around. Passenger rear window does not go down, other than that all are great
replaced upper/lower radiator hoses
Replaced front bearings L&R, I&O with seals and races
Rebuilt front steering knuckles
New ABS sensors and wiring harness and brake lines
new brake pads and rotors
replaced calipers with core charge
Other Details:
original seats are great. rear fold down seats are available, but not installed
after market rear diff installed by previous owner but works well
motor was reportedly rebuilt at 150K by previous owner though no documentation. It runs smooth and strong, with each cylinder showing good compression. Does not burn oil
Lots of other smaller projects inside and out - too numerous to list!
high lift jack and jack stands
tool kit with misc tools
Lots of extra parts included
