I have an 89 base yota pickup. It has the 3-0 V6, manual trans. I started hearing a squealing U joint the other night after a lengthy 4wd trip in snow. I just figured. No big deal I will have to change a U joint. WRONG!!
I have had blazers and such in the past and when they go out you spend a few bucks beat one out beat a new one in and go on.
Apparently the little japanese guy that engineered the yota thought it necessary to cost you an arm and a leg to replace worn parts in a front shaft!
What in the world is the deal on the CV joint in the double cardan? I pulled out my manual and it says DO NOT DISASSEMBLE FRONT SHAFT! I live in southern KY and finding someone to rebuild something like that will be like finding a brain surgeon at a Lady GAGA concert.
Called the only place in the area that does them and he says he "toyotas are getting hard to repair" said he USED to get parts out of CA but the place had left him.
Sooo.....here I set with my front shaft out and the only thing I am seeing is $398 or so at places like O'Rielleys. What do I do to cut corners here?
I already have $5K in a $2600 truck. Parts are outrageous to say the very least. Used parts are non existant around here. I have been looking for a tailgate for 2 years.
Anyone have a suggestion? I am mechanically inclined but have never had the pleasure of working on a CV joint nor do I want to. I just have the truck to hunt out of, put the boat in from the bank during the winter, and not be homebound during snow. I don't use the truck to rock climb, mudd, etc. so I don't need an upgrade as it only gets put in 4wd occasionally.
Where would be the cheapest yet dependable place to get one of these over priced over engineered beauties?
Thak you in advance!
greg
greg
