Anyone have the 2006 or 2007 2UZ-FE VVTi engine specs for stand camshaft lobes HEIGHT?
Might be interesting to see if we've any difference between VVTi and non -VVTi camshaft lift. A VVTi engine was blown after T-belt break, and I'm just investigating if it was fluke or true interference engine.
Below is the 2001, 2UZ-FE, FSM, EM, Cylinder head, inspect cam lobes, Standard cam lobe height:
Intake:
41.94 - 42.04 mm (1.6512 - 1.6551 in.)
Exhaust:
41.96 - 42.06 mm (1.6520 - 1.6559 in.)
Minimum cam lobe height:
Intake:
41.79 mm (1.6453 in.)
Exhaust:
41.81 mm (1.6461 in.)
Intake & Exhaust Valves have the same part numbers for all 2UZ-FE *** from what I've found. Camshaft part # are different as they should be do to gear/actuator, but lobes may be the same for all years.
Intake:
Exhaust:
Intake:
Exhaust:
