Hi y'all,
I have a 1987 FJ60, 183k, that I just bought a couple of months
ago. It had been driving fine; noisy, but fine. Suddenly, about a
week ago, it started failing to shift into second. If I go for a normal
1-2 shift, clutch all the way in, it grinds gears and will not go into
second. Similarly, on a 3-2 downshift, it won't grind, but it also
won't go into 2nd. My first though were the syncro's, but the more
I think about it, the less I think that that is the cause. For one thing,
it started really suddenly, not some notchy shifting over time. For
another, I've found a trick for successfully shifting the 1-2 about
half the time with no grinding. If I do a 1-N-1-2 shift (1st down to Neutral
between1st and 2nd, then immediately back up into 1st, then down into 2nd),
it works around 3 out of 5 times. When it does work, I can almost
feel something aligning as it goes back up into 1st. I searched the
archives and found some references to 2nd gear issues, but nothing
specific. Does anyone have any idea what could be causing this,
and if so, how I would go about fixing it?
(Shifting 1-3-4 till further notice)
-BH
-BH
