I've got a '87 FJ60 stock. I've removed the rotor and hub from the truck, I've removed the two 14mm bolts from the back of the rotor that appear to bolt the rotor and hub together. I can't get the hub and rotor apart. The studs for the lug nuts seem to go through the rotor and the hub but are they pressed into the rotor? Do I have to remove the studs before I can separate the rotor and hub? What's the trick here? I found several YouTube videos but they are for other years and they aren't the same.
Thanks,
Jabran
Thanks,
Jabran
