For Sale 85901 AZ - FJ40/55 DRIVELINE
AZ
  1. 40 Series
  2. 55 Series
If you see any parts off this and want it let me know or come haul it outta my yard whole for 800$.
Has 81k miles but sat most its life. Cylinder 3 is zero compression and has a bent exhaust pushrod. Has HEI on it, and a weber 38/38 thats been tuned. It ran fine on 5 cylinders and I drove it home from the carb shop like this. Also has the weber to stock intake adaptor but i bought it from a crap company with even worse customer service so it doesnt fit at all. New water pump. New plugs. I have a new valve cover gasket for it as well.
transmission is a 3 speed on the tree. Worked fine. Transfer case presumably operated but I never put it in 4wd so I would just say unknown.
‘69 FJ55.
‘69 FJ55.
Yeah thats what i pulled it from. I have the original carb still too. And original distributor and stuff from the HEI and 38/38 swap
Bump - $600 and come take the drive line, the 3 on the tree linkages, the engine hand crank rod, and all the other sh(t I no longer need from this engine.
