Jack up and secure the front of the truck with wood blocks or jack stands.
Remove front tires.
Get paper towels, wrench's and get ready to get greasy.
10mm socket
12mm socket
14mm socket
17mm socket
snap ring pliers
small screw driver with thumb sized handle.
big hammer
really big hammer
milk crate or you can use the tire
short 6 inch or so bungee cord.
Inner axle seal.
Hopefully you keep the front of the truck pretty clean. if not clean off the knuckle before you take it apart.
Do not use a high pressure washer on the felt seals. you will spray water into the knuckle.
Do spray off the 10 mm bolts that holds the felt and wipers on the inside of the knuckle.
Do spray off the steering arm and the nuts and nut recesses on the top of the steering arm.
Use penetrating spray on the top nuts and cone washer area.
Let them soak.
Turn you lock out hub to the locked out position.
mark with a piece of tape on the lock out hub where it is pointing.
There are several ways the lock out dial can fit into the lock out hub. Only two of them are correct due to the way the lock out dial spring is mounted to the back of the dial.
Remove dial.
remove snap ring on the axle shaft.
remove the 10 mm bolts and metal parts that hold the felt, metal ring and rubber wiper on the back of the knuckle.
Remove the nuts from the top steering arm studs, use a small screw driver and remove the flat washers.
You now can see the tops of the cone washers.
Now cone washers can be a pain to remove.
Some times you can hit the bottom of the arm with a big hammer and knock them loose. If this is working remove them as you get them loose as they can drop down and lock in again.
If that is not working try a small punch in the gap in the washer and see if you can move them a bit. then try the big hammer again.
Tap up on the front of the arm for the front washers.
Try Tapping down for the rear washers.
Now that you have the steering arm loose, use the bungee cord to hold it up out of your way. If there are thin spacers under it, save those!!.
now the knuckle will be hanging there on the top bearing.
you will use the small screw driver handle to push it down while you lift up on the knuckle. YES it is heavy. Also make sure that your milk crate or tire is very close by but at least 8 inch from the brake rotor.
do not use your thumb to push down on the bearing. I came pretty close to cutting the end off mine!!!
see Thumb.
WRONG.
Correct!!
now when it comes up off the bearing be ready, it is heavy and your hands are covered in grease.
in one motion. pick it up, tilt it down and turn it toward the back of the truck.
it will slid off the outer axle, set it on the tire or milk crate. don't drop it or you can split your brake line.
Don't let it hang by the brake line!!!
line up the flat part of the birfield top and bottom to pull the axle out.
Remove front tires.
10mm socket
12mm socket
14mm socket
17mm socket
snap ring pliers
big hammer
really big hammer
Inner axle seal.
Let them soak.
Remove dial.
see Thumb.
WRONG.
Correct!!
I did the same thing to my '85 30K miles ago.
