- Location
- United States
http://denver.craigslist.org/cto/4742925432.html
85' fj60
Only rust is drivers side rear wheel well
2f with 170k miles
Desmog
Trollhole carb
Newer windshield
96 4Runner wiper arms
New water pump
New thermostat
New engine mount
New exhaust
New side cover gasket
New oilpan gasket
New valve cover gasket
Valves adjusted
New clutch master and slave, clutch feels great
New plugs and wires
Upgraded coil
New choke cable
2 year old brakes lots of life left
IPF h4 upgrade with wire harness
New pinion seals
New output shaft seals
Allen key fill and drain plugs
Optima battery
Urban cruisers battery cables
Rebuilt PS pump
New steering gear box
New fuel pump
New alternator
Rebuilt starter
ARB lockers front and rear
Air line to fill tires
4.56 gears
Longfield axle and hub gears
Spring over axle conversion
62 springs and c&t housing
All new bearings in axles
Nice steering stabilizer mount
Custom driveshafts
Trail gear rock rings and lifetime wipers
Marlin crawler hi-steer
37x12.5x17 nitto trail grapplers siped with lots of tread
Safari gard front bumper
Spector rubber matting in cargo area
New dash cap
Nice stereo and speakers
Fj62 hand throttle and grab bar
New horn contact
2 LOW mod
Full size spare
interior is complete
Drivers seat just started to tear
Leaks a little from rear main but barely add half a quart between oil changes.
I'm sure I'm forgetting some stuff, the only reason I'm selling is because I need a work truck. Only trade I'll except is 12 valve cummins.
85' fj60
2f with 170k miles
Desmog
Trollhole carb
Newer windshield
New water pump
New thermostat
New engine mount
New exhaust
New oilpan gasket
Valves adjusted
New plugs and wires
Upgraded coil
New choke cable
New pinion seals
Optima battery
Rebuilt PS pump
New fuel pump
New alternator
Rebuilt starter
4.56 gears
Custom driveshafts
New dash cap
New horn contact
2 LOW mod
Full size spare
