- Location
- United States
**Price drop to $10k or best offer**
I'm currently juggling three vehicles and it's just too much to handle.
Many have probably scrolled through my previous post's for this truck, so it may seem familiar, although due to a number of issues discovered during the sales process last December a substantial bit of work has been completed.
To start, I am a Merchant Mariner. This means I work for 3 months at a time and then come home for approximately the same time. I try to spend my time playing and traveling when I am off, which is why I ran into problems when I put the FJ60 up for sale last winter. I hadn't been around the previous 6 months and the truck deteriorated a bit as it sat in storage. It came as a surprise to me as I started digging into it a bit that a couple of leaks and a rough idle were the tell tails of some larger problems.
Turned out at the time that there was a leak in the radiator, a blown head gasket, a faulty steering gearbox, a leaking gasket on the transmission and transfer case, oh and a new fuel pump was needed. Of course, these discoveries were made right before i left for sea again, leaving me with not a lot of time do to anything about it. I ended up taking the truck to the mechanic and had them spend 2.5 months sorting out all the issues.
When I came back from sea, the truck was running like a top.
THE TRUCK:
1983 Toyota Land Cruiser FJ60 with a TBI Chevy 350 (~55k miles) and a GM Automatic Transmission.
All original seats included, although rear seats are folded down and a sleeping platform has been constructed.
ARB front bumper with 8000# Smitty Built Winch and 2 KC Floodlights.
Defender Rack full top roof rack.
Custom steel rear bumper with 2" hitch. Can accommodate Swing Out, although never added.
(5) 33" BF Goodrich All-Terrain T/A tires with 90% tread. (Inc. Full Size Spare)
Manual front locking hubs.
Old Emu lift.
Steel center console lock box.
Dashboard mounted radio. (although AM/FM antenna not hooked up)
THE WORK:
As I mentioned, quite a lot of work has been done on it recently.
-The head was removed and serviced from the block up. New gaskets, new ignition electrical (distributor, plugs, wires)
-New steering gear box
-New inline fuel pump
-Refurbished radiator
-New brake system (brakes, lines and master cylinder)
-New steering and suspension bushings
-Rebuilt alternator
-New portion of exhaust manifold piping
THE NEGATIVES:
-No air conditioning (although fan & heater work well)
-Piece broken off driver side tail light. (small ding as well from same incident)
-RPM gauge isn't working
-Drivers window is stiff rolling up
-1 of the KC lights is shining. I think its a wiring issue after the relay b/c the other works fine.
-Interior headlining is separated in a few little sections. Could be restitched, but mostly in tacts.
-Minor rust developing around rear wheel wells, particularly driver side.
Having put in all this work (I have receipts to show) and the overall condition/ cleanliness of the truck, I am asking $10k, or best offer. Truck is located in St. Petersburg, FL but I am willing to deliver. If you have any questions, feel free to send me an email or text/ call.
Check out the Google Drive to see lots more pictures:
FJ60 Pictures
Cheers,
Ian
(305) 393-0496
ianholtzworth.out@gmail.com
THE TRUCK:
Old Emu lift.
THE WORK:
-Rebuilt alternator
THE NEGATIVES:
FJ60 Pictures
Cheers,
Ian
(305) 393-0496
