81 FJ40 in St. Cloud Minnesota - $2600
FOR SALE 1981 FJ40, near Minneapolis, MN $2600
This FJ40 needs a good home and is ready for a frame up.
THE GOOD:
-124,000 miles, 2F engine, 4 speed, front disc brakes, power steering, ambulance doors
-it's an 81, with an Old Man Emu lift and nice 31’s
-it has around $7000 in new parts installed over the last 10,000 miles. The larger items include new clutch, new but used transfer case, OME lift, Con-Fer skid plates for spring u-bolts, u joints, rear wheel bearings, tie rod ends, tires, alternator, etc
-have original manual, jack, tool kit, etc. (tool kit bag is a mess)
-has shield design steering wheel, gray interior, and steel white spoke wheels only found on the newer FJs
-has power steering that was installed in late 90s. Truck was not purchased with power steering
-the frame is solid
-I have maintenance records for the last 40,000 miles
THE BAD
-truck is currently not running, it’s been in storage for last 4 years
-rear drums need to be rebuild due to corrosion – pads are new at 113,000
-brake pedal is soft....air or master cylinder issue. (master cylinder isn’t very old)
-exhaust system needs to be replaced
-original radio is missing
-previous owner screwed a lock box to the center console
-truck is rusty due to life in Minnesota and nearly every panel on the truck needs replaced or repaired
-the rear of the tub is really rough
-back door lowers are shot, fronts might be saved with some lowers
-the original hood is shot, but I have a clean hood from a 78 which is the same as an 81 I believe
-top sides are repairable, but bad enough I was planning on buying new ones
-the fiberglass part of the top is good
-windshield needs to be replaced
I bought this knowing it was going to be a frame off restoration at some point. I figured if panels were rusted through a little or a lot they needed to be replaced just the same. Contact me at scott_greenthumb@yahoo.com for the quickest response. I have lots of pics. Thanks Scott
any interior pics?
More pics
Trying to figure out how to post more pics. I'm getting a quota exceeded message. Thanks.
43 Pics on Snapfish
I can't seem to post any more pictures. Go to snapfish.com and enter the following to view them.
email: scott_greenthumb@yahoo.com
password: 12345
Click on the favorites album in the middle of the page. All the pics I have are there.
I don't have a better way to get people good pics. The truck is about 60 miles from me so if more pics are needed ask and I'll try and get them. Thanks for the interest.
