Wanted 81 FJ40 FAN SHROUD
Waco Tx.
I am needing a fan shroud for my 1981 FJ40.
stock a/c or non a/c? they are different
Vintage Air. I just added it and my truck is running hot now. I had to move the radiator back closer to the fan to accommodate for the ac coil and my truck never had a shroud. hoping the shroud will get it under control. running between 215 and 225 with ac and pulling a trailer with a sxs, 20mph head wind nothing in my favor. had to pull over at one point climbed over 225 but cools off fast. I dont think i ever went much past 190 before no matter what i had on back or other conditions. worried about Texas heat in summer.
Consider getting a brand new fan clutch. Barring that, IIRC @Mark W did a great write up on repacking the original clutch with new silicone for Toyota Trails...15 or 20 years ago! ;)
Paul, was the lip on the AC shroud wider than on the non-AC shroud? I think I have one with a wide lip, whereas most I come across do not.
Are you thinking my fan clutch may not doing its job at higher RPM?
40 year old part? Nah, why would I think that? :p
I’ve always made it a practice in my business to ask questions and do my best to sell somebody what they NEED, even if it isn’t what they asked for. ;)
I wouldn't think those would be a wear item HA. I think I did replace the fan blade a few years back when I first got the truck but yes probably the original clutch. Do you have a shroud that will fit for my year model? '81. We have a sheet metal shop where I work and could probably fabricate one if I needed to. Thinking it should probably have a shroud anyway.
I don't recall the lip being wider, all the width on the a/c shroud was gained on the passenger side of the shroud.
I can check when I get home tonight.
Mark, the bolt lip appears the same size/width as non a/c shrouds.
Paul
