80s Cylinder Head Cover Gasket
hobbes
SWFL
Installing a 1987 2F from a 60 series in a 70s FJ40. I ordered, and installed, a new cylinder head cover (valve cover) gasket PN 11213-61011. But now I’m wondering. The gasket cross section is the shape of “l” and sort of snaps in the cover (I added a touch of sealant to make sure the rear stayed put). I’m used to the inverted “T” cross section gasket which appears to offer more sealing surface.
So am I using the correct gasket? Are all the 80s 2F gaskets like this? Or should I use a different PN?
Thanks....
Thanks....
post a photo of your valve cover itself u are using , thats what matters
here is my Dealership parts Dept. Fast Mover
hope this helps
that should take 11213-61011
Sounds like its correct then.
I just put a couple spots of sealant in the back of the valve cover to ensure the gasket stayed put during assembly.
just dont over-tighten the 4 grommets hex nuts , moderately snug is good
The 3FE manual has 78 in lb listed (6.5 ft lb). I stopped before that as that seemed too much. I see now those are different part numbers.
