- Location
- United States
I am selling a complete OEM 80 series subtank system located in Houston Tx. This includes the following:
-OEM stock 25 gal tank w/oem sensor for subtank
-OEM 13 gal subtank
-Dual filler neck
-Fuel transfer ECU
-Transfer pump and solenoid with all attached components
-Overhead console with compass/fuel guage/ light assembly (non sunroof type)
-Both OEM visors in grey(short versions)
-Fuel fill door with decal
-Removed interior decal (mounts on DS shifter console)
-Sub tank switch with pigtails
-Complete overhead wiring harness with compass magnet/bracket
-Fuel system wiring harness
-All hoses included
-All mounting straps for both tanks
-Rear tank sender access cover for truck floor
-Included Hardware
**Note: This is was all removed from running/driving vehicle.
As mentioned this is complete to about %98. All is needed it to wire the overhead haress into the transfer switch and to the chassis harness behind the DS kick panel. Everything else is plug and play. Since the overhead harness was part of the dash harness, there was no way for me to seperate all the needed wires. It was cut halfway down the "A" pillar. Plenty to work with.
I removed this with the intention of installing it, but I carry plenty of fuel on my AT. Someone could get more use out of this than I so for sale it is. $1350 takes all of it. Shipping can be arranged. I will also post pics as soon as I can locate my da*n camera cable.
A detailed write up can be found here : https://forum.ih8mud.com/80-series-tech/213266-oem-subtank-retrofit-install-project-pics.html
I was provided with great info about this tank system. I thank elmariachi for his great realtime info. Thanks for looking.
-OEM 13 gal subtank
-Dual filler neck
-Fuel transfer ECU
-All hoses included
-Included Hardware
