80 series /lx450 resources cheat sheet (1 Viewer)
tejas
i like to have everything easily accessible in my phone. plus i’m not all that familiar with auto repair/servicing so i have to get a tad OCD about it. if i am not mistaken this is a mashup of information from the mud FAQ’s formatted through the owners manual information.
not sure if anyone will find it useful but through to post it. obviously if experienced LC/LX owners have corrections or suggestions i’m all ears.
formatting is a little screwed up in the cut and paste but if anyone is interested i could post the text document after i proof it.
if something similar is out there already i’d be interested in a link.
LEXUS LX 450 RESOURCES + SPECIFICATIONS
GENERAL
MODEL: 1FZ-FE
TYPE: 6 cylinder in line, 4 cycle, gasoline
BORE AND STROKE: 100.0 x 95.0 mm 93.94 X 3.74 in.
DISPLACEMENT: 4477 cm^3 (273.1 cu. in.)
VALVE CLEARANCE (engine cold):
intake: 0.15 - 0.25 mm (0.006 - 0.010 in.)
exhaust: 0.25 - 0.35 mm (0.010 - 0.014 in.)
DRIVE BELT TENSION: 80 +/- 20 lb.
with burroughs drive belt tension gauge no. BT-33-73F
LUBRICATION SYSTEM
OIL CAPACITY
drain and fill
with filter change: 7.2 L (7.6 qt. / 6.5 imp. qt.)
without filter change: 6.9 L (7.3 qt. / 6.1 imp. qt.)
OIL GRADE: API SH, energy conserving II multi-grade engine oil or ILSAC multigrade engine oil]
RECOMMENDED VISCOSITY: see owners manual
> CHEVRON delo 5W30
> MOBIL 10W40
> ROTELLA synthetic 5W40
COOLING SYSTEM
CAPACITY
with front heater 13.7 L (14.5 qt. / 12.1 imp. qt.)
without front heater: 14.7 L (15.5 qt. / 12.9 imp. qt.)
COOLANT TYPE
ethyl glycol based coolant (do not use alcohol type)
distilled water (1 gallon)
FUEL
FUEL TYPE: unleaded only
RESEARCH OCTANE CAPACITY: 91 (octane rating 87) or higher
IGNITION SYSTEM
SPARK PLUG
MAKE: NIPPONDENSO K16R-U or NGK BKR5EYA
GAP: 0.8mm /0.031 in. gap]
ELECTRICAL SYSTEM
BATTERY
maintenance type battery
specific gravity reading at 20dC (68d F)
1.280 fully charged
1.180 half charged
1.080 discharged
charging rates:
quick charge: 15A max
slow charge: 5A max.
non-maintenance type battery
open voltage at 20d (68d F)
12.7V fully charged
12.3V half charged
11.9V discharged
[voltage that is checked 20 minutes after the key is removed with all the lights turned off]
charging rates: 5A max.
TRANSFER
OIL CAPACITY: 1.7 L (1.8 qt. / 1.4 imp. qt.)
OIL TYPE: mutlipurpose gear oil API GL-4 or GL-5
RECOMMENDED OIL VISCOSITY: SAE 75W-90
AUTOMATIC TRANSMISSION
FLUID CAPACITY
drain and refill: up to 2.0 L (2.1 qt., 1.8 imp. qt.)
FLUID TYPE: automatic transmission fluid D-II or DEXRON II
> synthetic ATF
> any name brand DEXRON IV
DIFFERENTIAL
OIL CAPACITY
front
with front and rear differential locking system: 2.65 L (2.8 qt. / 2.3 imp. qt.)
without front and rear differential locking system: 2.80 L (3.0 qt. / 2.5 imp. qt.)
rear: 3.25 L (3.4 qt. / 2.9 imp. qt.)
OIL TYPE: hypoid gear oil API GL-5
OIL VISCOSITY:
above -18dC (0dF): SAE 90
below -18dC (0dF) SAE 80W or SAE 80W-90
> REDLINE gear lube 75W-90
> MOBIL 1 gear lube
> AMSOIL gear lube
> CHEVRON delo gear lube (ESI 80W90)
BRAKES
PEDAL CLEARANCE: 68mm (2.7 in.) Min.
minimum pedal clearance when depressed with the pressure of 490 N (50 kgf, 110 lbf.) with the engine running
PEDAL FREEPLAY: 3 - 6 mm. (0.12 - 0.24 in.)
PEDAL BRAKE WEAR LIMIT: 1.0 mm (0.04 in.)
PARKING BRAKE LINING WEAR LIMIT: 1.0 mm (0.04 in.)
PARKING BRAKE ADJUSTMENT: 7 - 9 clicks
parking brake adjustment when pulled with the force of 196 N (20 kgf, 44 pbf.)
FLUID TYPE: SAE J1703 oe FMVSS No. 116 DOT 3
BRAKES: DB1365/4WD lexus 96/07 LX450 (F) or EBC greenstuff 100 series pads with drilled and slotted zinc coated rotors.
CHASSIS LUBRICATION
WHEEL BEARINGS: lithium base wheel grease, NLGI No.2
> HD wheel bearing grease
STEERING KNUCKLES: molybdenum-disulfide lithium base chassis grease, NLGI No.2
PROPELLER SHAFTS: lithium base wheel bearing grease, NLGI No.2
STEERING
FREEPLAY: less than 40mm. (1.6 in.)
POWER STEERING FLUID: automatic transmission fluid DEXTRON II or DEXTRON III
> MOBIL DTE 24
TIRES AND WHEELS
TIRE SIZE: P275/70R16 114H
TIRE INFLATION PRESSURE
recommended cold tire inflation pressure
vehicle load up to four occupants
front: 220 kPa (2.2 kgf/cm^2 or bar, 32 PSI)
rear: 220 kPa (2.2 kgf/cm^2 or bar, 32 PSI)
vehicle load up to vehicle capacity weight
for sustained high speeds above 160 km/h (100 mph) add 80 kPa (0.9 kgf/cm^2, 0.8 bar., 12 psi) to the front tires and rear tires. but never exceed the maximum cold tire pressure molded on the sidewall.
WHEEL SIZE: 16 x 8 JJ
WHEEL NUT TORQUE: 103 N-m (10.5 Kgf-m, 76 ft-lb)
DIMENSIONS AND WEIGHT
OVERALL LENGTH: 4820 mm (189.8 in.)
OVERALL WIDTH: 1930 mm (76.0 in.)
OVERALL HEIGHT: 1870 mm (73.6 in.)
WHEELBASE: 2850 mm (112.2 in.)
TREAD
front: 1595 mm (62.8 in.)
rear: 1600 mm (63.0 in.)
VEHICLE CAPACITY WEIGHT (OCCUPANTS + LUGGAGE): 524 kg (1155 lb.)
FUEL TANK
CAPACITY: 95 L (25.1 gal., 20.9 Imp. gal.)
FAN CLUTCH
[ ] silicone fluid: 25 ml refresh; 40 - 48 mil full drain
08816-03001 (3,000 CST)
08816-06001 (6,000 CST)
08816-10000 (10,000 CST)
6,000 or 10,000 for texas
KYOSHO is third party brand name
OTHER
[ ] OIL FILTER [get drain plug gasket]
90915-20004
[ ] AIR FILTER
[ ] ALTERNATOR BELT (90916-02353-83)
[ ] V-RIBBED BELT (99332-10910-83)
MISCELLANEOUS
[ ] graphite liquid (cables)
[ ] distilled water (1 gallon)
[ ] seafoam
[ ] corrosion block spray
[ ] sonneborn NP-1
[ ] 3M throttle body cleaner
[ ] carburetor cleaner
[ ] CRC MAF cleaner
Thanks for putting this together!
There is probably some overlap in the tech data, but below is a quick reference guide that I pulled off of MUD a few years back. As a suggestion, I would try to format your list into a double sided reference card. Laminate it, keep it in the truck, and you'll always have it at your fingertips.
Additionally, attached is the dealer brochure spec. sheet for the '97 LX450.
  • 80 series reference card - short.pdf
  • 1997LXspecs.pdf
thanks man. printed those two out. the lx brochure is nice to have.
so if anyone is interested i proofing that i will probably print it out doublesided card stock. as it stands i have mingles’ here which i am studying.
one question popped up. @mingles are we talking 1.6 liter between the marks on the dipstick or 2.0? i’m tracking oil loss now and this is pretty much how i am doing it. so far i have been working with 2 liters and not 1.6...
thoughts?
I knew I had seen that somewhere before.
Thanks for the reminder!
(Original thread)
