I have a few 80 series LED dome & door kit available right now.
Complete interior dome kit, lower door kit
and as a bonus I am including the rear license plate bulbs for free (LIMITED to quantity) .
$55 SHIPPED Via USPS Priority Mail
PM me or for fastest response
Hit me up Allkindofcoolstuff at gmail
Door LED Maximum light output
Front Dome (without cover ON)
2nd Dome (without cover ON)
How to install door.
Slide door light housing to one side (one side has a metal spring clip).
Carefully remove clear plastic lens (there are four delicate plastic tabs)
Install bulb AND CHECK POLARITY (make sure the bulb lights up as LED are polarity sensitive) if bulb DOES NOT light you can either turn the white socket around OR switch the black terminals around)
Pull of the rear sticky backing and apply the light to the light housing.
Place plastic len cover back on and return to the door panel.
Front DOME
Remove the single screw and remove the plastic Lens.
(DO NOT pry like the previous owner of this 80 series did AND damage up the cover)
THIS ONE WAS THE TRICKY-EST. The bulb socket, has to be twisted into the socket. Which is manageable but is tricky as the bulb housing has two small studs that need to seat into the socket metal clip. Again make sure the bulbs polarity is correct. If bulbs does not light up. Turn the black terminal around.
I place the LED bulb right onto the plastic clear lens and replace the lens back onto the housing.
You can use the adhesive backing if you like, but make sure its lines up with the lens
2nd and cargo area is just as easy. Just make sure to check you have the polarity right.
The 2nd and cargo uses a wedge style connector.
Hope you enjoyed the write up.
Front DOME
