80+ closed chamber head on 78 block w/ pop up pistons
Reno,
Does any one know if the late closed chamber heads could be used on a motor with the earlier pop up pistons? Seems like away to increase compression and supposed better flow.
Thank you in advance.
Mike Haberthur
I'm thinking there is clearance issues
shave the head down for increased compression
Thank you. I had planned on shaving the head, but just thought that the swap might be the way to go. I understand all the rockers and assorted stuff needs to be changed also.
