No you can re use your axles and brakesDid you have to change the rotor size when you did this installation?
| FJ CRUISER | GSJ15R-GKASKQ | GSJ15 | 11.2010 - 08.2016 | ATM,MTM: AUTOMATIC TRANSMISSION; |
Technically no, because I used my former axle shaft assemblies. But when I do use the axle shafts that came with it (and I will, once I've rebuilt the hub bearings), I will have to install the slightly different rotors from a 2010+ FJC.Did you have to change the rotor size when you did this installation?
What size rotors are you going to use?@92RedToy
I didn't use the new axles right away because I didn't know the history (original or rebuilt hubs?) and I had recently rebuilt the hubs in my old axles.
Are you going w/ different rotors simply because your gonna use different hub bearings that are bigger or is the axle shaft flange to large?@92RedToy
I'm on deck to rebuild the rear hubs/axle assemblies that came with my 8.2" axle housing. They've been collecting dust at the garage and now one of my current bearings is complaining. I threw a code for interference with wheel speed sensor and inspected it last weekend. Something (dust cover?) on the tone ring has separated from the bearing face, so wonky signal, so no ABS, so no A-Trac, etc.@92RedToy
I’m surprised you didn’t get the bearings from partsouq. Even with shipping, could have saved a 100 bucks.Some dealerships have parts on deep discount and free shipping right now. I order the following from Toyota Parts and Accessories Online - Serra Toyota of Decatur in Decatur, AL - https://parts.toyotaofdecatur.com/
Total was $620 shipped!
RETAINER $15.48 Qty: 2 42423-60050
BRAKE DUST SHIELD (LEFT, RIGHT) $15.25 Qty: 2 42441-60060
GASKET $1.51 Qty: 2 42443-60010
DRIVE AXLE SHAFT BEARING (RIGHT, REAR) $246.55 Qty: 1 42450-60050
DRIVE AXLE SHAFT BEARING (LEFT, REAR) $246.55 Qty: 1 42460-60010
WASHER $2.93 Qty: 2 90208-44001
DRIVE AXLE SHAFT SEAL (LEFT, RIGHT, REAR) $4.94 Qty: 2 90310-58003
RING $1.80 Qty: 2 90520-41019
BOLT $3.67 Qty: 12 90942-02079
Wow, didn't even think to check with them. $180 vs $245. And the Koyo assemblies are $75!I’m surprised you didn’t get the bearings from partsouq. Even with shipping, could have saved a 100 bucks.
Its strange they both were bent. Usually only see one bent from a pair due to side impact or something. More amazing that the housing they came out of is straight, every 8in I've pulled parts from had a bent housing if a flange was bent. Thicker material on the 8.2 must actually be a thing.It never occurred to me when I rebuilt those axles that they were bent.
Honestly, it could have been the freight company that damaged it en-route. It was simply strapped to a pallet and not very well protected.Its strange they both were bent. Usually only see one bent from a pair due to side impact or something. More amazing that the housing they came out of is straight, every 8in I've pulled parts from had a bent housing if a flange was bent. Thicker material on the 8.2 must actually be a thing.
Great info on the 8.2 though!
I was wondering how that might have happened- truck was probably on a lift and they made quick work to cut the axle off and it dropped it on the floor below-Honestly, it could have been the freight company that damaged it en-route. It was simply strapped to a pallet and not very well protected.
