SOLD 78/79 FJ40 engine parts
WA
Two water pumps one w the clutch and pulley
Oil pump out of 78
Alternator out of 78
Alternator bracket
Smog pump brackets
Charcoal canister
Carb cooling fan, works
Other stuff
$260 plus shipping. It'll be heavy.
Interested in the harmonic balancer, the alternator and the cooler pipe. Can you get pics of them from other angles? Alternator has a pre-69 pulley, so I’m interested to see the clocking of the case, as well as the plug attachment. HB would like to see the seal surface. Thanks.
Would be interested in your main bearings too.
You're # 2 on balancer but is got grooves. Ill put you down for alternator, cooling pipe and bearings. Will pm you
Alternator
HB...rough.
Bearings
The following have sold:
-Cooling fan
-Pulley
-One smog pump bracket
-Charcoal Canister
-Engine lift hook.
- Alternator brackets
