77fj40 headlight switch bulb replacement?
Olathe , Kansas
I,m a newby to the website....I just purchased a 77fj40 and I,m in the process of going through bulb replacement throughout the dash....My question is ...how do I get to the bulb that lights the the headlight on/off switch?...doesnt help that I have poor eyesight and can barely see the assembly underneath the dash...is the bulb at the back of the assembly or do I need to remove the entire assembly to get at it?....any help would be greatly appreciated...Thanks for your consideration!!!:bang:
Welcome.
It would be far easier to remove the headlamp switch assembly to replace that little bulb on the back of the switch.
Small Phillips head screw driver will remove the knob and a snap ring pliers with a strait tip that fits into those two pin holes on the switch nut works well to get that switch removed from the dash.
Good luck.
