- Thread starter
- #21
Thrashed rear cross member is gone.
nice clean fibbing on the spring purches, motor mounts and rear cross member (I only wish) ... are your putting the tail-lights back into the cross-memeber ... looks like you have the cutout marked out ...
Did you upgrade the bolts that hold the skid plate on or just stick with the original ones? Any more detailed pics of the rear d-train mount?
Cool! Glad to have you follow along.Cool project! Subscribed ~
Just as a warning I bought the same transmission pan for my 700R4 and it does not clear the u-joint and front drive shaft. I had to put the thinner factor one back on.A few pictures of the some of the new pieces going into the frame soon. Radiator arrived today, as did the aluminum trans oil pan.
I have a 700R4 in mine also. I bought a new TV cable from TCI. I learned the hard way what to look for when installing the cable. If you can, attach the cable with the trans on the bench and with the trans on it's side and the pan off verify that the TV cable will move the TV plunger the full travel.
My TCI cable had a manufacturing defect that didn't allow full travel. I found out when I lost 3rd and 4th gears after about 100 miles. It was a costly learning experience.
Notice on the fitting where it is swedged to the cable that there are ears created from the swedging process. On mine the ears were so wide it didn't allow the fitting to go all the way up the cavity in the cable end. It felt good from the carb side and I even had it adjusted at a trans shop. The trans had a kit in it which raised the fluid pressure so the shifts were hard. This covered up the issue that might have been noticeable on a stock trans. This picture doesn't show it well, but I circled the one visible ear.
Even after filing the extra material off I had to shim the cable housing end up a little to get full travel on my replacement trans.
<a href="http://s378.photobucket.com/user/srgould41/media/images_zpsc94b2c7e.jpg.html" target="_blank"><a href="http://i378.photobucket.com/albums/oo222/srgould41/images_zpsc94b2c7e.jpg" target="_blank"><a href="http://i378.photobucket.com/albums/oo222/srgould41/images_zpsc94b2c7e.jpg" target="_blank"><a href="http://i378.photobucket.com/albums/oo222/srgould41/images_zpsc94b2c7e.jpg" target="_blank"><a href="http://i378.photobucket.com/albums/oo222/srgould41/images_zpsc94b2c7e.jpg" target="_blank"><a href="http://i378.photobucket.com/albums/oo222/srgould41/images_zpsc94b2c7e.jpg" target="_blank"><a href="http://i378.photobucket.com/albums/oo222/srgould41/images_zpsc94b2c7e.jpg" target="_blank"><a href="http://i378.photobucket.com/albums/oo222/srgould41/images_zpsc94b2c7e.jpg" target="_blank"><a href="http://i378.photobucket.com/albums/oo222/srgould41/images_zpsc94b2c7e.jpg" target="_blank">
I don't have a picture of my trans pan, but because the front drive shaft is so close to the pan I needed to cut the lip down at the rear edge and hammer the front corner of the pan in. You can't do that on an aluminum pan so check carefully in case you need to return your pan in favor of a steel one.
Keep up the good work!
nice build ... man, it made me shudder about what you found with the sandblasted tub ... that is a PITA ... no berliner here, but my tub is allegedly "original" that was "refreshened" due to faded paint ... it doesn't look too bad, but who knows ...
Aside from the usual FJ40 rear sill issue
, it is in MUCH better condition. The existing sill possibly could have been salvaged, but we're so deep into this it just made sense to replace it all.
. I have a few more pieces to ship off plus my personal collection of OEM FJ40 hardware. It looks so nice I can't resist (insert imagination again).
