SOLD 74 Carb linkage
hyhpe
here
  1. 40 Series
140.00 shipped. Not sure if it is complete nor if the pieces are all from the same year.
Just an FYI those are specific to a '74 with an F motor. It works on a 2F however it puts the linkage rod at a more extreme angle since the manifold is not as deep as a 2F manifold.
Also the corresponding carb bracket must be from a '74, the later 75-80 bracket will not work, it will bind and not allow the throttle to open.
The longest rod on far right isn't used, just another linkage rod. Same goes for loose rod, 3rd from the right, but you'd just need to select the correct length rod to allow for full rotation.
If you clean them and zinc plate them they're worth way more. 😂
