cruiserbrett
GOLD Star
Trying to make sense out of a used carb I bought and am going to make work for the time being to send my 73 FJ55 original carb off to Jim C for a rebuild. Truck is at sea level, stock F engine.
Someone, at one point put a carb kit in it, but the jets were not legible, scraped with screwdrivers, etc. and the 180 jet was in the primary side and the 120 in the secondary side. power valve jet had no number legible, etc. So to get a good baseline:
So, this is what I have so far:
Main Jet: 120
Secondary Jet: 180
Power valve: 60, but I have a 55 and a 90 as well.
Now my question is this: there are the two long idle correction jets. No legible numbers on these. One is longer than the other, and they have two different sized holes. Is it safe to assume that the larger hole one goes on the secondary side since the manifold vaccum would be lesser, and this would allow more air emulsion?
Large hole air correction jet: Secondary????
Small hole air correction jet: Primary?????
Anyone with some insight? I did rear the 73/74 thing in the tech, but some of my jet numbers dont match, so I am trying to figure out what will work.
If there are some tuning changes, let me know...
Main Jet: 120
Secondary Jet: 180
