71 series new Arraives 2008 V8 DIESEL
I don't know about this one but they certainly did on the HDJ81, with the exhaust kink everyone seems to have above the rear crossmember.
They didn't on the BJ-7x series
wrong angle, you got to crawl further down and look at the cross member above the shocks...
Wait, I'll take a picture...
Here it is...
By just removing the resonator on my HZJ73, and replacing with 2 1/2" straight pipe, I gained 3 seconds 0 to 100 km/h. Prior to that change, the engine did not want to pull above 3000 rpm..
I am not suprised... The exhaust is definitely a limiting factor especially at high RPMs, Martin White saw a huge difference when he had his exhaust redone...
At this point I'm collecting the parts required to do it myself, I'll certrainly post when I do with my findings (before and after acceleration and fuel consumption)..
I'm sure it will work great :) I got myself a Magnaflow 3" on sale so I should be good as well... Just looking for a 3" SS pipe supplier at this time... Don't believe for the short run I'm planning that mandrel bent is a necessity, and I'd rather avoid as many welds as I can...
Well, it you don't use mandrel bends then you will be down to 2.5 inches which is still good - but not as good as 3 inch mandrel. Lots of welds aren't bad. There is a guy in town here with 3 inch stainless, and I can get the mandrel bent j pipes if you need them in stainless or regular steel.
I'm still too busy and have tons of other things to do first but you sure make it very tempting for me to let everything go and just get to your place and get things done there...
Here it is...
Nope, the frame on the BJ-7x is different, there is no channel cross member for the pipe top go over.
Besides the problem with the pipe in the picture is not the diameter, it's the kink that nearly closes the pipe off. Nothing works right if it's not maintained.
That kink is common to all HDJ81s AFAIK. Martin White had the exact same problem, and was told by ATEB they were all like that. Nothing to do with lack of maintenance or some other sort of problem, it's apparently by design.
In any case redoing the exhaust solves the problem. Why am I not surprised...
That kink is common to all HDJ81s AFAIK. Martin White had the exact same problem, and was told by ATEB they were all like that. Nothing to do with lack of maintenance or some other sort of problem, it's apparently by design..
in the picture posted the exhaust pipe is clearly KINKED about half closed, and I doubt if it comes from Toyota like that. It comes with a smooth bend, but it's obvious in the pic that someone backed up against something and kinked the pipe, then part of the end rusted of. Clearly a maintenance issue. The design isn't all that great, I'll admit, and I'm glad they didn't do that design on the 7xs.
No kidding John, I just simply can't find the link to this. I'm am sure Martin White reported ATEB as saying it was a factory restriction.
I know it sounds weird, but I remember that very clearly. Something to do with limiting torque.
Whats the correct model number for these new cruisers? At a dealer I saw one with stickers on the windscreen calling it a 79 Series (however I had a 79 series for work and it was the old shape and 6cyl turbo)
This thread is titled 71 Series, but I have a brochure from Toyota naming it the 70 Series (however the swb isnt featured, only the tryaback, wagon and troopy)
Sean
Sean
Only a handfull of markets still get a SWB 70 or 71 series. The one signifies a turbo version in some years and in others it means coil front and the new one has both,well so did the previous model:confused:.
The ones pictured above are ME models and not usually diesel,maybe they are dropping the old 1FZ FE.
Makes me wonder if the 7* series will ever see a V8 petrol;)
The V8 cab chassis is still a 79 series although the dealers are referring to all the new V8 models as the 70 or 79 series depending on who is talking.
(there is no longer a body plate with all the details on the firewall)
Much of the confusion is caused by the fact that since 1984 all the numbers from 70-79 have been used up.
They should have released the new models with a alphabetical suffix to signify it is from new generation of 7* series.
Make the most of them as I believe this will be the last model. With OHS laws becoming more stringent, it will probably be compulsory to have airbags and Toyota have already stated they cannot be fitted to a 7* series.
Personally I cant see them dropping the line completley, there is just too much need for vehicles of this sort... Nissan have no problems fitting airbags to the Patrol, and Toyota fit them to the 100... Its just a case of a major redesign to incorporate airbags.
I know where I work, there is no other option for what we do, other than a toyota troopy, without heavily customising another full chassis 4wd (deffender/patrol)
Sean
