70 Series rear axle stabilizer bar
Hello,
70 Series front axles have a stabilizer bar.
Was a rear axle stabilizer bar ever offered? Was an aftermarket setup available anywhere?
Juan
I have a rear bar on my 79 that was supplied with my coil conversion kit, that was from Superior Engineering in Oz. Also the GXL 79's had one from the factory I believe.
Hello,
Do you have pictures of it?
Juan
Hello,
Thank you so much.
Juan
HZJ79s used p/n 48805-60100. if you google that part number you'll find photos. I have some old stock I can sell but shipping is going to be weird. I have some mounting brackets as well.
Hello,
Thank you for the information and pictures.
It appears to be a long wheelbase option.
I wonder if it can be fitted to a short- or mid-wheelbase model.
Juan
Does your rear axle have mounting brackets for the bar? If not I have some weld on ones going spare. They came with my kit from Superior but I didn't need them.
Some 76's also had a rear stabilizer bar so should be possible to retrofit, although you may have to do some welding
Hello,
Thanks for the heads up. I will check.
Juan
