His case has two separate spacers, one is slightly wider than the other and not shown on the diagram above. To determine where the spacers need to go, I'd position the PTO output housing and "hover" it over where it bolts up. Take a guess and install the PTO gear, transfer case input gear and spacers. Note the location of the PTO gear teeth on the output shaft. They need to line up with the "driven" PTO gear just right. If they don't, swap the spacers around until they do. A bit of trial and error but there's only so many ways it can go and the PTO driven gear is "fixed" so it's a good reference.
The shorter one is the 'stopper' and goes between the transmission and t-case input gear. The long one goes between the rear t-case bearing and retaining nut. This assumes the two gears that fell out are the t-case input and PTO gears.
