69 brake help ...
Portland, Oregon
i have the original shoes front and back. I need a source of rebuild kits for the back brake cylindars.
And, i also need a source for the master cylindar kits.
Any ideas.
I ordered the fronts from our local distrubuter, but the slave pump cups were about 5 mm to small. i reused the old ones which were in very good condition.
i may need new return springs on the shoes.
something is hanging up in there, and the brakes lock up.
I think Kurt from Cruiser Outfitters, has complete wheel cylinders for $30~.
Edit: But now you need to find out exactly what you have..
help with sensors ...
here is my master brake cyclindar... what are the sensors on teh bottom for?????
Wow you sure thats a 69? Or did you swap out the old single res. master for the dual/booster? I would try searching the vendors on this site or go with the front and rear disc.set-up.Thats what I am going to do on my 69.
John
OOps just read your sig. line and saw that it was a later model setup! Good luck w/the brakes.
For a front/rear (later model) fail warning light, which I doupt your '69 has.
If the PO didn't upgrade the brake lines and wheel cylinders right, that could be the root of your problems.
