Hi All,getting a little closer to try and start her up! I have a few basic connections left.Accelerator & choke cable linkage,I don't know how to hook these to the carb.Some close up pics.would help alot.Also where does the wire on Solenoid valve on the carb.go,ground or to the coil?
Also Vacuum switching valve has a ground but no other connection.Looks like it may have snapped off,I never remember this connection before when I had it running.I am looking at the Haynes manual(I also have the F-eng. FSM).Pretty good pic.on the vac.routing.Still trying to figure out all the connections.
My clutch release cylinder also seems a little different to bolt to the engine.Seems as I may have my motor mount on wrong,the pics in the manuals don't show the way it bolts on.I have one bolt that I saved from my old F,do you use both holes or just the one.Looks like it lines up with the MM.
Thanks,John
Thanks,John
