Thanks for the advice here, got them thru Lift Depot. Easy 20 min job, $51 delivered.
McMaster CarrWhich ones from McMaster are you guys using again?
...For my 88 FJ62 the extended length is 17", compressed 11", and the
lift rate is 90#. This may be the same for FJ60s but I can't be
positive.
Just a heads-up. These are NOT the correct dimensions for the '89 FJ62. Ordered a set to the above size, and now I've got to send them back. Should have known to just measure mine. My struts (on the '89) measure 16.25" by 11".
Just a heads-up. These are NOT the correct dimensions (17"x11") for the '89 FJ62. Ordered a set to the above size, and now I've got to send them back. Should have known to just measure mine. My struts (on the '89) measure 16.25" by 11".
The later FJ-62s must have different mounting locations.
I took the studs out on three cruisers, two of them rusty. No problems, just go slow.
Yes the mcmaster carr studs will not thread in unless you force them, the thread pitch is different.
If you are carefull with the grinder it is no problem cutting them out.
Well I just threaded the McMaster Carr studs in with seemingly no problem. I hope that I didn't damage the threads when I screwed them in, but they seemed to go in well...well perhaps a bit tight. I also used anti-seize compound on the threads.
Has anyone who used the McMaster's ever removed them yet? If so, were the threads damaged?
Zack
OK. I'm not as smart as a strut. How do the people that know what they're doing compress the strut to get it on the ball?![]()
