60K service on '18 LX 570... Shocking!
No reason to replace AHC shocks in pairs. You can replace the ones leaking and be absolutely fine. Got pictures of the rears?
I could see the seals on your shocks possibly having dry rotted given the low miles and correspondingly low cycling of the shocks. Ya gotta use the poor thing! :)
Could be, however my 2013 thats 5 years older with sub-14k miles on original suspension had zero dry rot or leaks.
The AWD service is just a catch-all term that is used since we have other “4 wheels driven” vehicles.
It’s just a differential and transfer case drain and fill.
I’d wait on the shocks.
I can’t view the labor times for Lexus vehicles, but $1700 for the front at, say, $200/hr is 8.5 hours. I’ve never replaced LX shocks but I’ll assume that time also includes an AHC bleed.
If you DO decide to replace the shocks, especially all of them, and if you have a decent service advisor, they’ll cut a deal on the labor. If not, go somewhere else that will.
Great news that I can wait a while til servicing the shocks/struts. I am a little disappointed that mine are showing seepage at such low miles though. Thought these would last a LOT longer.
Put the truck full height, wipe them down with some glass cleaner or similar, check for seepage again next service.
I have the same bleeding shock issue with 50 k miles on an 18. There is no apparent ride change and I lift and lower it all the time. One thing I did was add AHC fluid to the reservoir. Helps me sleep at night.😬
While this is what I want to hear, I hope that is true and "all LX's look like that".
I can’t tell you I monitored this well throughout the course of my LX’s life. I didn’t touch anything on my suspension until 325,000. Rode fine. And probably would’ve been fine. I replaced struts, springs, and globes. May function a little better, but not noticeable.
I went from a 14 LX with 150 k miles to an 18 with 50 k miles. There is a difference in ride quality.
