60 SUA with 35 inch tires (pic)
Pendleton Oregon
Website
www.oregongrain.com
Here is the 60 with OME heavy, Shackle Reversal, and LT315/75R16 Toyo Open Coutnry MTs.
With those wheels I get rubbing in the rear under full compression. Pic taken yesterday.
looks pretty good though! you have the same wheels (not tires) as me. May sound kind of crazy, but who makes them? I have no idea what brand of wheels I'm running.......
SOA conversion should cure that problem ;)
-db-
What gears are you running?
My OME 2.5" lift with stock size greasable shackles seems to sit lower but I'm on 33's.
Does a shackle reversal give you a little lift as well?
Are you running the stock 2F and 4speed trans?
Sweet.... Is the SR a kit or custom fab?
I love a 60 on 35"+!
I like the stance of that 60, maybe I'll do something similar.
bull said:
It does rub in the rear. Next up is some swaybar disconnects.
in the front man... the lower edge of the front of the front wheel wells... oh, the disconnect wont help the rubbing i dont think as the more the flex, the more the rub in the inner wheel well right?
BlueCruiser84 said:
do you have other pictures? maybe from a side view or another angle so i can see the rear wheel well. Is the rear just a 2 1/2 inch lift spring?
Brian
he had to run extended shackles to compensate for the SR on the front.
Damn that 60 looks great! I have one just like it but not as stout. I'm slowly workin on it all the time. I'll try to get some pics on the site. Hey there local Wa. Seattle here. Good work on it.
