60 C-Channel Repair Rails
Do you think in the future you will be selling left and right rail section from the mid point back to the c channel some day?
Not as a std stocking item. The extended version I posted a picture of in your thread was a custom set and they went to Canada. The cost gets up there on these and in some cases you can find a better frame for a little more money...
J
HI,
Anyone make a frame patch for the frame section around the front spring hanger for the rear leaf springs?
I decided I would like to order a set of repair rails with grade 8 hardware for my 1983 FJ60, do you have those available right now?
-Sean
my corrosion starts in the inner channel "missing metal half way up the frame rail inner" all the way back and 1/4 the way up the arch hump over axle. Got a replacement channel that I can put in place for both sides? the shock tube snapped off from corrosion long ago, so outter channel will eventually need to be replaced or strengthened.
The C-channel replacements are awesome. I do have a question though. I had to cut out the rear bumper crossmember, and the bolts don't allow the spare tire crossmember to fit. Do I need that spare tire crossmember?
