60 Series Production Chassis
TRAIL TAILOR
Enabler
Supporting Vendor
Redding, California
Website
trail-tailor.com
TRAIL TAILOR 60 SERIES CHASSIS
2” x 5” x .188” wall A500 laser cut frame rails
Laser cut and CNC bent bracketry for accuracy
1.75” x .313” wall front and rear adjustable 4 links with 80 series OEM bushings
Fox Racing coilover shocks and steering stabilizer (remote reservoir and adjusters upgrade available)
TK1 Racing front and rear sway bars
Trail Tailor 80 series style 8” high pinion front (4.10 gears with Eaton e-locker standard option )
Trail Tailor 80 series style 9.5” full float rear (4.10 gears with Eaton e-locker standard option)
4340 CrMo front and rear axle shafts (standard option)
4 corner disc brakes with rear e-brake (front Powerbrake upgrade available for front only)
80 series steering box (105 sector shaft upgrade available)
Brake and fuel line options available
Extended range fuel tank option available (NOT FOR SALE IN CALIFORNIA)
Trail Tailor adjustable front panhard bar
Will ship on GUNY wheels (standard) or optioned wheel/tire combinations
Designed for Trail Tailor high frame clearance rock sliders (select mfgs bolt up)
Designed for Trail Tailor front and rear bumpers ( OEM and select mfgs bolt up)
Select motor/transmission/transfer case mounting solutions
Chassis powder coating option is available pending selected options
Chassis builds are made to order. Lead time 12-16 weeks
PRICING
Base chassis with GUNY wheels- 36,500.00
Chassis as pictured with options- 45,700.00
As pictured is optioned with 12” front/10” rear travel FOX Racing shocks, front Powerbrake stage 2 two piece rotors and 6 piston calipers with 35 x 10.5 x 17 tires and Raceline beadlocks, 45 gallon extended range fuel tank, Set up for LS3, TR4050. Approx. 4.5” suspension lift.
Set the body on the chassis this morning.
Should lower down about perfect with all the weight I need to still add. Figure about 2" drop in rear and 4" in the front. Looking for a .75-1.00" rake when finished.
Stretched out at 108.75" wheelbase.
LS3 Erod with 2.9L Whipple, TR4050, HF2A, front and rear bumpers, 130# rear bumper mounted spare, sliders, dual batteries, skid plates, 45 gallon of fuel, small rear storage box, seats, console, interior cargo roost rack.
