So, who's interested in getting a group buy going for 4x4Labs rear bumper kits?
Bumper kit info and welding how-to: https://forum.ih8mud.com/az-copper-state-cruisers/142286-4x4labs-rear-bumper-build.html
Here's a recent price list:
Rear Bumper Kits
Basic bumper- kit $495 Welded and finished $895
1 main bumper shell
2 sides
2 side top tubes
2 d-ring points
towing crossmember
receiver
Single swing out bumper- kit $895 Welded and finished $1375
1 main bumper shell
2 sides
2 side top tubes
2 d-ring points
towing crossmember
receiver
1 large spindle assembly
1 swing arm assembly with 4 sleeves
Latch and latch plate
1 gas strut with ball stud
2 stoppers
Double swing out bumper- kit $995 Welded and finished $1495
1 main bumper shell
2 sides
2 side top tubes
2 d-ring points
towing crossmember
receiver
2 large spindle assemblies
2 swing arm assemblies with sleeves
2 gas struts with ball studs
3 stoppers
15. Accessories
Tire holder- kit $125 Welded and finished $225
Swing out clamp bracket
Main upright
2 gussets
side clamps
top cap
3 hole tire holder
square tube receiver
3 wheel studs
3 lug nuts
Hardware
One, two or three gas can- kit $195 Welded and finished $395
Main upright
2 base gussets
2 tubing hoops
tube spreaders
bottom plates
2 basket gussets
License plate bracket
Hi-lift bracket with standoff
Ladder #1 – kit $150 Welded and finished $350
2 Base tubes
2 rungs
Ladder #2- kit $175 Welded and finished $375
The first rung on this ladder is sleeved just like the swing arms for a third accessory like gas cans or a cooler. It can be removed for regular access to the ladder.
Main hoop- long, you cut
1 round rung
1 square sleeved rung
Cooler basket- kit $225 Welded and finished $425
Main upright
2 base gussets
2 tubing hoops your supplied dimensions
tube spreaders
bottom plates
2 basket gussets
ARB fridge basket- kit $225 Welded and finished $425
Main upright
2 base gussets
2 tubing hoops
tube spreaders
bottom plates
2 basket gussets
Bicycle rack, 2 bikes- kit $195 Welded and finished $295
Main upright
2 base gussets
Rear tire plates
Rear tire plate crossmember
Rear tire hold down straps
2 skewer tubes
2 skewers
Safety hook
Top cap
Logo plate
16. Separate bumper parts
*Main Shell- Formed and plasma cut bumper shells for FJ80 and FJ60 $185
*Uncut formed main shells 72” wide- $125
*Formed laser cut side skid plates- $125 ea.
*HD Spindle assemblies- $95 ea.
*Swing out assemblies- HD spindle assembly, sleeved swing arm with gas shock, ball studs and stops - $225 ea.
*Accessory bracket clamp- $25
*Towing receiver- $25
*D-ring tow points- $30 ea.
*Hi-lift bracket- $25
*License plate bracket- $10
*De-sta-co 4000 lb. Latch and latch plate- $95
*Gas struts 120 lb. $25 ea.
*Ball studs $2.50
* 6" or 8" Gusset $9
*Accessory carrier retrofit sleeve/clamp kit- $29
*Using our retrofit sleeve and clamp kit our detachable accessory system can be retrofitted for use with any other rear bumper system with a 2” swing arm (ie. Kaymar, Slee, Man-a-fre, etc.)
- Citadel-80 series rear
- davegonz-100 series rear
- warpdriv-80 series rear
- Cool Breeze-80 series rear
Rear Bumper Kits
1 main bumper shell
2 sides
2 side top tubes
2 d-ring points
towing crossmember
receiver
1 main bumper shell
2 sides
2 side top tubes
2 d-ring points
towing crossmember
receiver
2 stoppers
1 main bumper shell
2 sides
2 side top tubes
2 d-ring points
towing crossmember
receiver
3 stoppers
15. Accessories
Main upright
2 gussets
side clamps
top cap
3 hole tire holder
3 wheel studs
3 lug nuts
Hardware
Main upright
2 base gussets
2 tubing hoops
tube spreaders
bottom plates
2 basket gussets
2 Base tubes
2 rungs
1 round rung
Main upright
2 base gussets
tube spreaders
bottom plates
2 basket gussets
Main upright
2 base gussets
2 tubing hoops
tube spreaders
bottom plates
2 basket gussets
Main upright
2 base gussets
Rear tire plates
2 skewer tubes
2 skewers
Safety hook
Top cap
Logo plate
*Ball studs $2.50
