- Joined
- Dec 15, 2014
- Threads
- 19
- Messages
- 239
- Thread starter
- #21
Is the diaphram you're talking about the flying saucer shape disc that the VSV vacuum lines terminate into under the truck at the front of the t-case?
If your 4WD Lo manual shifter(and linkages) doesn't engage 4WD then the problem is not in the VSV's or the hubs.
php74 is probably asking you to confirm that with hubs locked you can't turn the driveshaft. If you can't that at least confirms the hubs are working.
Threeeeyedbandit,
My truck can go into 4Lo by moving the shift lever. The 4WD switch (for 4Hi on the dash) does not need to be selected. 4Lo engages 4WD regardless of switch position on dash.
Correct! Vacuum on one nipple will engage 4wd and the other will disengage it. Let us know what you discoverI am going to use a vacuum pump to apply major vacuum to that diaphragm. If it works and I get vacuum, my solenoid should actuate and I will not be able to turn my driveshaft?
I am going to follow this to its logical conclusion thinking that it is still a vacuum issue until proven otherwise.
I hope there's a rebuild kit for that diaphram if that turns out to be the problem.
I will post my results after Memorial Day.
Thanks for everyone's input.
Thanks, I appreciate having the theory of operation.Correct, but it isn't a mechanical 4wd selection. The low range switch disconnects the 2wd VSV via the 4wd relay and energizes the 4wd VSV. Disconnect the the low range switch on the tcase, and now you get the option of 2wd low.
Just clarifying how the system works![]()
